65hp johnson
"1968 V4 65hp Johnson. Yes, th
"1968 V4 65hp Johnson. Yes, that model has two (2) sets of points, located under the flywheel and distributor cap."
"I've never heard of any g
"I've never heard of any going bad but yes, they're still available, part number 383655. Rather expensive, about $30.00 each. Usually a little #600 saandpaper and a cleaning with either laqauer thinner or acetone returns them to new condition.
(Point Setting Of Battery Capacitance Discharge
( Ignition Models - 1968 thru 1972)
(Some have points - Some do not)
(Joe Reeves)
The points must be set to .010 but no wider than .010..... BUT in some instances due to a possible slight inaccurately machined crankshaft lobe or a slight offset of one set of points, a setting slightly less than .010 would be required as follows.
Whether the crankshaft has two or three lobes, when setting the points, check the setting of the points on each individual lobe by rotating the crankshaft by hand.
You may find that setting one set of points to .010 on one lobe, then turning the crankshaft to the next lobe, the gap measures .011 or .012 (too wide). This is where you would need to close that gap down to the required .010. A gap too wide can result in a ignition miss when throttle is applied.
Bottom line, pertaining to the point setting at the various lobe locations____ .010, .010, .009, is okay____ .010, .010, .011 is not!
"Okay, now whereinthehelldoIse
"Okay, now whereinthehelldoIsendthisbill? (grin)
