K
katzeng2
Guest
"Hello,
I have a
"Hello,
I have a 1964 Johnson seahorse 9.5hp. I'm having trouble keeping it running. I've replaced the fuel pump, cleaned out the carb and put a new jet and float in it, changed the fuel filter and have also tried a different fuel tank and primer bulb assembly. It runs longer then it did before and alittle bit longer if I give it some choke, But then it slowly dies. It only runs till you get about 50 feet from the dock and then dies Could you please send me in the right direction or maybe you already know of this as a common problem with this motor. The model # MQ-10R, The serial # J2479275.
Thank you, katzeng2"
I have a
"Hello,
