how much water should flow out the outlet. i was out on the lake with it first time with this motor and noticed that their was not a lot of water coming out it just kind of spitted and sprays out but no steady stream the boat has a red over heat light on it. and it works it never came on. the outlet is 3/4 inch or so, so i don't think it would flow steady but i have no idea . at idle almost no water comes out at full speed it kinda sprays. i think that i need a new impeller if so what level of difficulty is this. do you just drop the housing and replace the impeller and housing and line up and push back in place or is this way more difficult then a novice can handle
