Johnboatcaptainron
New to boat motors and this is my first post. Thanks for any help. I just bought two motors, a 50's model evinrude 7.5 and a 63 Johnson 10 hp model qd-24b. The 7.5 came with a good metal fuel tank. Both have good compression and needed some minor stuff. I gave 250 for all. I was told the 10hp was run last year and that's the one I am working on first. The recoil spring was broke and I stole the one off the 7.5. I pulled the flywheel and checked the coils for cracks and cleaned/adjusted the points to .020, they were a little tight. I still need to replace impeller, and get a female adaptor so I can plug up fuel tank, but I could not get the motor to hit at all after spraying a little fuel in cylinder. Before putting it away last night, I noticed something was not right with the throttle linkage. The throttle grip on tiller handle would not turn back past start to get to slow and stop. I thought maybe the little ring with the words was just misaligned. So I twisted throttle to what I thought start should be, and tried starting, and surprise it tried to start. I quit there(I had allready empty my water bucket). I noticed when I twisted the handle all the way, I could still pull the carb linkage over half way. Is there adjustment on that? It looks like the thing under the flywheel that comes all the way around needs to be rotated around some, the fatest part that pushes the little barrel looking thing out is a couple inches away from the barrel.(the barrel looking thing is connected to carb linkage) Sorry I don't know the correct term for this stuff. Don't even see them on the parts diagram.
