61 merc 22hp will only run in start
LARS991
Runs & idles in start position for 20 min just fine and when put to run dies after about 15 secs any suggests welcomed
Sounds like a ignition switch to me disconnect the kill wires from the stator should be two small wires coming out the points plate and see if it stays running
Has no battery and concern it has something to do with the advance sys also i was able to run by pushing the throttle ahead with finger several times and it accelerated all the up to just a guess by about 3000rpm with the lever in the start position and then let go of it and it idled just fine
