The Engine will idle just fine, then I start driving slow and for awhile it seems fine. Then when I increase the RPM and get closer to Wide open it start jerking and running rough. It continues to get worse and even hesitates when I take it back down to a slow speed and then I limp back to the dock. At first I suspected bad gas even though it was new gas. I ended up cleaning all 3 carbs and they looked pretty good. The bottom carb did have an internal gasket (the one that goes over the main tube in the float bowl chamber that had a rip in it. I didn't have a replacement one so I had to put it back together. Do you think that could be the problem? I also have tried changing spark plugs and fuel filter and a different gas tank. One other thing I noticed and thought was the problem was when I replaced the fuel filter with a clear one, the first time I primed the bulb I saw a lot of junk pushed into the filter. I stopped immediately and pulled the filter and emptied 4 small containers by squeezing the primer bulb with the hose (right before the fuel filter) aiming into a small cup. I did this until the gas was clean and then put everything back together. I assume the junk was from the previous fuel line and primer due to years of using gas with Ethanol ( I replaced that a week or two prior) The other thing I'm questioning is the fuel filter I replaced the original one with a universal inline filter so I didn't know if that could cause a problem. The last thing I checked is the compression and all cylinders were right around 100 psi.
I'm at a loss now and not sure what else it could be. Any help will be appreciated.
