"I bought the boat around the
"I bought the boat around the first week of May; it’s a pontoon boat with a 60 hp Mariner motor. I didn’t water test the boat before buying so it’s my fault that I have these problems. The motor started and ran fine on the water ears etc. it would start at the turn of the key. We ran a compression test on the motor while there; it had 115, 115, and 120 good numbers for a 1994 60hp Mariner. When I got it home I went ahead and changed the plugs, drain the gas tank, changed the water/fuel separator, changed fuel filter and checked the hoses and fuel bulb. Then we loaded it up and took it to the river, motor started and run but at WOT tac was only showing 3200RPM and it didn’t sound like it was screaming to the 5500RPM that the manual says this motor should turn at WOT.
I took the boat to a local boat mechanic (in his mind anyways) he cleaned the carb, and adjusted all the cables and greased this and that for a three hours labor charge @ $75.00 an hour. I took the boat back out and it still only turned 3200RPM when I called the guy back he said the tac was wrong, the motor runs fine. Also while out on the river after a few stops and starts the motor got where it would not start in N – I would have to disable the prop, (via the button on the throttle control ) start the motor pull back into neutral and then forward, sometime it would stall even when I did this. So I decided not to take it back to him, since the motor seem to run/start worst then before taking to him.
I took it to another boat mechanic (in his mind anyways) he checked a few things and said the throttle cable wasn’t adjusted right, I explained to him another guy just cleaned carbs, adjusted all the cables, throttle etc. He said he must have done it wrong,, I left the boat after explaining the first problem was that the motor would not operate at 5500RPM at WOT. I guess he must have done the same thing as the first guy and with no better results; I was charged three hours labor @ 60.00 an hour. He claimed to adjust carbs, adjust cables, check stator, (low and high speed checked OK) check ign boxes/coil drain and cleaned oil injection box, cleaned check valve for oil control etc. I took the boat out on the water again, same result 3200RPM at WOT. I had purchased a prop and decided to change the prop to see if any difference. I went from a 14 pitch prop to a 10 pitch prop. And that did as it should, picked up 800RPMs, so now the motor runs 4000RPM at WOT.
So I’m looking for suggestions,,,,, the carburetors should be cleaned since they were done twice, the cables should be adjusted since they were done twice (Which the motor is still hard to start for the first time in the morning and after a few hours of stop and starting it has to be started in gear so to speak, with the throttle in the run position instead of N.
So any suggests (other then dirty carbs, fuel lines, stator, these things I hope was checked by the two so call mechanics).
Thanks,"
Thanks,"
