I got my boat out of the shop about a month ago after replacing the whole ignition system. Also replaced with new parts, few pump, new gas tank and line and rebuilt carbs. Put dual stage Boyson reads on it. Ran real well when got out of the shop. I tried to lower the RPM's so I could do some trolling. By doing so, I dropped the RPM's and fiddle with the carb low-speed needle valve. Since then, I have had problems with hard starting and exceleration. Manual says to set needle valves 3/4 and start with the middle until I get the sweet spot. Still won't idle correctly. I almost think it is flooding itself out. When I do finally get it to run at half throttle she'll run real nice. Then drop it down to slow she will start to run rough. And sometimes she'll stall out. Then I go to start it and it seems I have to use the cold start/high level lever to get her to kick. And even then sometimes it won't start. If I let her sit for a few minutes then she'll start only with assistance of high idle lever. Joe Reeves gave me some feedback on the carb adjustments. Set RPM's as low as possible, starting with mid-carb, turn in 8th inch turns until highest RPM is reached. Then turn RPM's back down. Tried this but no luck.
In between carb settings do I need to drop RPM's or is it just the initial adjustment on the mid-carb? Either way, she won't run right. By me turning the idle speed needle out beyond the 3/4 or 1 1/2 turns it seems to want to run a little better, but again at start up it does not want to kick unless I wait for awhile. Also, the RPM's seem to fluctuate say I get her up and running with idle RPM's at approximately 650-700, do a few laps around the pond, drop her back in neutral, RPM's drop down to 300-400 and almost dies on me. And at times it will die. It seems it definately a carb problem. After dealing with this I took the carbs off for the hundreth time, took Welch plugs out, used carb cleaner and air and fine wire, adjusted floats, put muffs on it outside, got it to run great again. Went to the lake back to the same problem. Can someone please help me?
Thanks,
Tony
Thanks,
Tony
