boardhauler
I have a 1997 MM 60hp 2 stroke. It was in storage for 4-6 years after I bought it, without anything drained/prepped. So I......
rebuilt carbs
new pre carb fuel filter & hoses
rebuilt the fuel pump (main gaskets/diaphragms only not the valves)
drained the fuel tank, cleaned
new water separating fuel filter
new plugs
new water pump impeller, housing, gasket
new gear oil
fogged the cylinders with seafoam
put 50:1 oil in the fuel tank, just in case the oil injection had an issue
I ran it out on the water 2 times over 2 days. Overall it ran like a scalded dog, hit 39 mph in my 16' aluminum flats boat. Maybe it was not perfect, as I had not run it before or had any experience with older 2 strokes. The only issue was when I first started it and idled out of the canal, the overheat buzzer went off, but stopped once I gave it some throttle and water flow. It never came on again.
After that it sat for a few days, issues started. It was harder to start, would not idle well, and stalled every time I put it in gear. I found that the crap fuel filter I put in before the carbs had started to disintegrate. I think there was some glue in there that got pushed into the carbs. I found a translucent white goo in the bowls.
So I tore down the carbs and put them in the ultrasonic cleaner. But, the issues persisted.
I had not changed the float levels/adjustment to this time. They looked close to factory spec, I have the service manual. So I started to look at it closer. I could not adjust the float level to 9/16" as in the manual. The float would touch or come very very close to touching the top of the carb.
I picked up some MM carb gaskets and needle valves from a local dealer. And I noticed that the needle valves that I put in had a rubber tip/seat. The OEM MM ones were all metal. This change allowed me to get the float adjustment very close to the 9/16", probably closer to 5/8", but not perfect. I did have one needle seat that was not sealing well, so I polished it a bit with a wooden dowel and a sliver of 1000 grit paper. The carbs are 30 years old, so maybe the seats are worn enough to keep me from setting the float level perfect?
It is running better now, but still has issues idling. The only way I can get it to 1/2 way behave is to adjust the idle/timing screw when it is in the water to increase the idle speed.
There are a few things I have done along the way, multiple times to make sure everything was adjusted correctly......
link/sync the carbs
adjust roller cam clearance
check linkage and stop settings
set the timing in neutral, idling on the water muffs
checked the flywheel key and TDC on #1 vs the timing marks
adj. the idle screws/mix (I do get a lean stumble and back off 1/8-1/4 turn only as I adjust to get the highest rpm I can)
Here are some issues that I have noticed and can not figure out.....
I can set the timing to the factory spec at idle of 2 degrees ATDC (after top dead center), but it does not like it. I am setting this out of the water while on the ear muffs. The best I have gotten it to run, is after this initial setting, put the boat in the water, warm it up and open the cowl and turn the idle/timing screws until I get the highest idle that I can. I think it is ending up around 2 degrees BTDC. This does not match what I am reading in the manual???
After doing the above, I pulled the boat and when I was flushing the motor, I trimmed it all the way down (negative trim, back/aft of motor tilted down) and the idle sounded way better, stronger. Tilted it back up, and it bogged a bit. Still an issue with the carb float level OR idle circuit???
At WOT I am only hitting 4700 rpm. Over propped??? Is this also causing my stall when going into gear???
rebuilt carbs
new plugs
new gear oil
link/sync the carbs
