att. joe r. again you have solved by problem. the send wire i belive was hooked up on the wrong termenel block screw. there was a open space above the gray wire that went to the amp.. iread your post and moved the tack send wire to the yellow and gray off the recterfier. i wonder why i was even getting a rpm reading before. again it only was reading up to about 3k. i will see today how it works. now that it will pick up a pulse signel from the stator i think i will have a working tack. thank you.
