60 HP Merc TrimTilt Question
K
Keith Gruber
Guest
Please bear in mined you'
Please bear in mined you're dealing with a mechanically "declined" fisherman.
I have a 96 merc that tilts up fine but "gurgles" and hesitates going down. sometimes have to tilt up higher then down again to start the downward direction.
Fluid level looks good.
" Keith,
It sounds like the
" Keith,
It sounds like the pump is dry. This can happen if there is a leak, a bad check valve, a bad o-ring, etc.
Tony "
