60 hp johnson
harold541
i have had the carbs rebuilt
i have had the carbs rebuilt engine idles rough and dies when shifted into gear runs great at wot any thoughts as to what my problem is? thanks
"try,idling it up faster....u
"try,idling it up faster....u could also have a blocked LS jet..u can pull the breather off,and w/a rag,...slightly cover each carb throat and see if rpm picks up for a sec,if so,that ,is the offending ,lean running carb."
i'm going today and run a
i'm going today and run a compression test for my self and i'll take your advice i'll let you know the rasults good idea thanks for the help
i checked compression all 3 w
i checked compression all 3 were between 120 and 122 psi spark test on all 3 1/4 blue sparks tried a rag across the throat of the carb it choked down to near stall replaced all fuel lines and hose clamps replaced fuel filter i'm at a lose as to what to next any ideas thanks
