Hi Guys,
I've tried adjusting my carbs numberous times with no good results. Done everything possible. Today I am going to get new plugs and give it one last shot.
Joe Reeves has given me the run down on the settings. I've also picked up some feedback just looking through threads. One thing I have not done is adjust my idle with the boat in gear. Now by doing this my engine RPM will increase when I put it back in neutral to do the initial slow-speed idle. I'm hung up here as to what to do. After putting it in neutral do I drop the RPM's again? or do I adjust needles at that point? I've heard over and over to get the motor to the lowest RPM before stalling - then adjust. Also, this is a 3 cylinder and it states to start with the middle carb. Now say I have the RPMs set with motor in gear, needle valve out at 1 1/2 turns, turn in til RPMs increase and run smooth. At this point, do I lower the RPMs again and start on the bottom carb? Or do I leave the RPMs alone in between each carb low-speed setting. I've also heard to do the two bottom carbs at low speed then do the top carb at a higher RPM around 1,000.
I just want to make sure I have all my "T's crossed and I's dotted" before I get on the water. One other fact is that I have dual stage Boyson reeds I just installed. Some say this may alter the factory setting. If so, what information may be needed. One more thing I've heard the terms "lean and rich" stated over and over to get these two cycles to purr correct. By turning in the needles does this lean or richen or vice versa.
Look forward to getting some feedback.
Thanks,
Tony
Thanks,
Tony
