hi all.Mr joe R. has in the past explained to me that the power pack or in my case the amplifier lacks voltage do to the starter stealing the power. it was explained to me that a 12 volt diod could be instaled to eliminate damage to the amp.my 3 main? are what lead do i go to on the amp i have 1 purple 1 gray 1 blue and 1 lead going to the timer base with a plug in conector.and on the starter silonoid witch one is witch.can i go with a connector from the corect silonoid post direct to the terminal block in witch the amp is powered.what gage wire is used to install this diod.after looking at all the wireing on this i found that the wire comin off the safety switch part#0379542 is just capped off next to the starter silonoid. i have been running the motor 2 seasons without what does this switch do and do i really need it? thank you tony.
