HI all.
Need help, iv got a 2005 caver, 33 super sport, only had the boat for 4 mth but have done about 1200 miles in it bring it up the Australian east coast in a week, its running twin 6lt mpi crusaders,closed cooling systems with shaft drives.
My conncern is , both engines wont to run at 95 c, any where above 3000 rpm, cruising is at closer to 4000, temp stays the same, even after 6hr of continues use.
One engine 40hr the other 800 hr, the new engine was a long block with new heat ex and all the other bits that get replace when a engine has fauid due to a over temp fault, no strains fitted from factory on raw water pick up.
Both raw water impellers changed, didnt make any diffrence, pulled one thermostate, and went for a run, once it gets to running temp, both temps the same, as it happened the freash water pump has allso been changed, a leaking seal, still same crusie temp, have pulled hose and checked oil cooler and heat ex, very clean, starting to think this is the temp these engines run at, am blowing some steam out the exhausts, not the main stream marine engine over here and ever hard to get any advice other than, put in mercury engines, crusader are no good, ill stick with the crusaders
