I'm bringing back to life for my neighbor's 1968 CD-25A 6 hp Johnson that he got for free. I took off the head and the passages were completely clogged. I scraped all the passages clean. I installed new head gasket and thermostat gasket, new thermostat and seal, and new identical Champion plugs. I changed the impeller and tested the cooling at the heads with an infrared heat gun. It idled OK , and it spit out water well (no pee hole in this model). The heat gun gave me a max of 143 on the bottom cylinder, and 175 on the top cylinder just running it for 3 minutes. I never seen this before, I know the water passages in the cylinder head are spotless, I cleaned them.
OK, back to the drawing board - I removed the new thermostat, and replaced it with one that I removed the hat from it, the top part that opens and closes. I figure this engine runs a t high speed most of the time, so it might help. No change, it still runs 30 degrees hotter at the top cylinder
My Johnson 25hp and 115hp have water passage deflectors, but this 6hp does not show any in the parts diagram or the manual.
I'm stumped, any advice is greatly appreciated.
