Tommysmicroskiff
I do some repairs on small outboards but , can only do so much so I cleaned this one up made needed repairs ran it and then sold it ...It runs pretty good but NO motor is perfect so I told the buyer I'd check for answers from the experts ...
So here you go ...
"Actually, I have 1 question you may know the answer to. When I change gears (F/N/R) the motor tends to stall (when the load changes), come off plane quickly, etc. I took the carb apart and cleaned it with carb cleaner (spray can). I noticed with the slow speed jet that there seems to be a check ball in there- is that normal, or it it clogged? The main jet is clear.
I also noticed that the top line coming off the carb (not a fuel line)- it runs across the top of the head, back to the oil side, has a small hole in it- could that be my issue from a lack of pressure?
Ive looked online quite a bit, but figured you may be able to answer straight away. Thanks so much for any help you can provide-"
So here you go ...
