Good Morning,
I am finishing up a rebuild of an old Gray Marine engine, essentially an inline 6-71, two valve head, normally aspirated with older style pistons, see below picture.
The original engine had old style injectors, advanced timing, and .81 inch liner ports. On advise, I installed N65 Brown Tag injectors and new liners, but at 1.05inch and set standard timing. I kept the old pistons and just replaced the rings. After the initial rebuild I could not get it to start, it seemed to be down on compression and I am wondering if there is incompatibility with the larger liner ports and old style pistons. I see that my pistons have all 4 compression rings grouped together, whilst a lot of the cylinder kits being sold have the top fire control ring a lot higher up.
With the change in liner ports should I have replaced the pistons also?
Another thing is that the service manual I have states that all 2 valve heads should be run with standard timing, but elsewhere it states that the N65 brown tag should be run with the advanced timing. What should I do here? I'm not sure of the difference between white and brown tag is.
I also cannot find the differences between a 71, 71E, 71M or 71N. Anyone know? I understand that the 71T is the turbo.
Any help appreciated,
Richard
Richard
