Ayuh,..... Exactly, How are you feeding it water,..??Hello I have a 2002 Mercruiser 6.2 with Bravo One outdrive that will not pump water into the engine. I have replaced the impellor twice with no luck. Does this outdrive have a second water pump somewhere or could it be the engine water pump? Thanks for any help
Thanks for your help. I have replaced the impellor about 4 or 5 times since I bought the boat. I was looking at bottom left (facing foward from the stern) of the engine thinking that was the sea water pump. You mentioned an impeller kit. Does that give you more than the impeller. I have a new impeller which I will replace tomorrow. A few years back I found that the empeller housing was cracked and replaced it with a brass one. I am going to try and sand the inside of it as it is not as smooth as the plastic oneIf you’re facing the engine, looking towards the rear of the boat, the sea pump is on the bottom left. The power steering pump is on the bottom right. And the engine water pump is in the center. The fuel pump and cooler are behind the power steering pump and hard to really see since it’s at the bottom of the engine. Or it could be on the same side as the sea pump depending on year. Also there is no way the sea pump impeller lasted 20 years, maybe 5-6 and that’s pushing it. The impeller kit is around $120 and yes it’s kinda of a pain but only because of the exhaust manifold. I am replacing my exhaust manifold and elbow and the sea pump is easy to get to when that’s removed. A mechanic would probably charge $300-400, but couldn’t really tell you since I do all my work on my boat.
Could the water pump on the front of the engine have failed. I never thought of that until now. The engine has very low hours compared to its age. 248Thanks for your help. I have replaced the impellor about 4 or 5 times since I bought the boat. I was looking at bottom left (facing foward from the stern) of the engine thinking that was the sea water pump. You mentioned an impeller kit. Does that give you more than the impeller. I have a new impeller which I will replace tomorrow. A few years back I found that the empeller housing was cracked and replaced it with a brass one. I am going to try and sand the inside of it as it is not as smooth as the plastic one
How do you get to the sea pump. Is it in the outdrive? Thanks for your help
Ayuh,..... The muffs might be leaking to badly to push the water up to the raw water pump,.....So I took the sea pump off. The impellor looks good. I have a spare but since the one in it seems fine I was thinking maybe their is another problem. So I hooked a hose to the out drive and turned it on. No water was pumped into the boat. Why wouldn't water go into the sea pump.
Is there a valve that would stop water from getting to the sea pump
are you sure the water comes through the drive and not a intake on the hull bottom?So I took the sea pump off. The impellor looks good. I have a spare but since the one in it seems fine I was thinking maybe their is another problem. So I hooked a hose to the out drive and turned it on. No water was pumped into the boat. Why wouldn't water go into the sea pump.
