"I can't keep my 5L Mercru
"I can't keep my 5L Mercruiser running at idle. Engine is 2004 purchased as leftover in 2005 and installed in Sept.05. Ran great through breakin and last season. Brought from ramp to dock at my home early this summer where it sat. Suspect fuel went bad during winter layover (some of it has been in the tank for a few years) and lack of use during season. Changed water separator fuel filter and cleaned out carb inlet filter. Disconnected fuel tank and running on portable tank with fresh gas. Engine fires right up and runs great but stalls when choke kicks off. Starts right up and runs at about 1500 rpm but will stall when I try to bring to idle. Can't shift into gear. Just want to get boat to ramp to haul. Carb is 2bbl has SAE J1223 MARINE written on it. Single Idle mixture screw but it has a seal on it.
Tried carb cleaners, Seafoam and WD40 all improved things a little but still stalls. Also even replaced distributor cap and rotor since it seemed to have some moisture.
Any suggestions to get it running enough for the 15 minute trip to the ramp?"
