Hello newb here and need some help .I purchase this eng from an ol guy down in the keys looks brand new. He started it and went through the gears it idled fine and seemed to run ok at the twist of the throttle. It had a good stream of water and the oil light stays on. I got it home and hung it on my boat it's a 9 ft plastic porta bote don't laugh it works ,weighs about 65 lbs. Stared right up and rand fine at low rpm tried to get up to speed and it is bogging down motor just doesn't sing. I took the carb off and it was spotless, so I removed and cleaned the 2jets and blew everything out wit air . Reassembled ad tested same thing . I took the cover off and manually throttled it up in neutral I can get decent rpms but under load boggs down any help ? Thanks.
1500440
BF5A
BADE 1302241
1500440
BF5A
BADE 1302241
