"If you have the cables you ar
"If you have the cables you are well ahead of many people having the motor. One source I know of wants $135 for a replica cable from the motor to the battery. You might consider using the starter switch from an old International tractor. Connect the ground cable to the battery. Connect the positive cable to the switch and the switch to the starter. Eliminates the spark given off when shorting direct to the battery or engine block. If you use the touching cable method, which I do NOT recommend, connect the positive cable to the motor and the battery (as in use the bolts and nuts), connect the negative to the battery and touch the free end to the motor. DO NOT TOUCH TO THE BATTERY AS THE RESULT COULD BE EXPLOSIVE. I can not express that enough. Do not EVER connect the starter to the battery by shorting the wire to the battery terminals. As for the box, watch E-bay, post a wanted on Craigslist, aomci.org, the classifieds here, and any where else you can think of, and try not to hold your breath waiting for one. Sorry I can not give you any better news or ideas."
