57L Mercruiser Fuel Pump
badair
"My 1999 Searay is having an i
"My 1999 Searay is having an intermittant fuel pump problem. It won't start because the fuel pump doesn't come on when you turn the key. I checked some connections and then it worked, but it's not working again. When a fuel pump goes bad is it intermittant? Where is the pump located?
Brian"
"Hey Brian, you may find faste
"Hey Brian, you may find faster and better service if you post your problem in the Mercruiser section. This is the outboard section.
