"I have a 5.7L mercruiser with
"I have a 5.7L mercruiser with weber 4bbl carb. During dewinterization, the engine was idling rough (hunting rpm, stall at low rpm). I fixed the timing which was way off, and replaced a corroded distributor cap and rotor. Still rough idle. I pulled the plugs (new end of last season) and checked compression on the cylinders. The plugs were black and wet with gas. The cylinders had anywhere from 140# to 168#. The manual references 150#, and the lowest compression cylinders had the least fouled plugs. The cylinder at 168# was the wettest of all.
I am lost here now. Should I clean up the plugs and give it another shot? Is 800rpm too high at idle? The manual references 650-750rpm in forward gear, can this be correlated to an idle rpm? Can bad gas cause all of the above (I used stabilizer all winter)? Is a carb rebuild the next step or is there other troubleshooting that I can do?
Thanks in advance for your time and support.
Matt"
Matt"
