"Hi fellas, I'm at wits en
"Hi fellas, I'm at wits end. My 86 Bayliner is still overfueling. New everything. Dist, coil, wires, plugs, fuel pump, a/s valve, carb, etc etc. I'm getting trace amounts of gas in the oil pan, and the plugs are fouling. You can smell raw fuel through the exhaust even underwater, and pulling the breather hoses off the valve covers you can smell raw fuel when it's running. I can turn the idle down very low, adjust both mixture screws all the way in and the engine won't change pitch. (2nd carb and fuel pump). Same symptoms.
Question 1: If my fuel pump is putting too much fuel to the carb, would it do this and if so what psi should my mechanical pump be putting out.
Question 2: If my cam is washed (I have 150 PSI on all 8 cylinders compression) would it do this?
It idles perfect and runs fine until the plugs foul.
Focus on the problem that I am getting too much fuel in the cylinders to cleanly burn and I can't adjust the carb at all!! Seems to me overpressure to the carb?!! Could I have been handed the wrong psi replacement pump. The original had the same symptoms but I disected it to see if it was a causal factor and the diaphragm was fine.
My spark is tremendous, everything from tank to carb is new, all electrical is new, compression perfect! Everything tuned to specs. Same problem.
300 hours on this boat. Any ideas.........
El Pescador, my email addy is [email protected] I'll gladly pay you for advice. I'm in Michigan, summers closing out and this is the 3rd year I haven't been able to run. My wife thinks the boat is the bank that only accepts deposits at this point and she's definitely going to come uncrimped if she finds my reciept file on this boat when I tip over...lol.
Great forum, everyone's wonderful, please....help."
