"Hi I have a 1997 5.7 mercruis
"Hi I have a 1997 5.7 mercruiser. The problem I am having is a lack of power when in gear & trying to accelarate. History is had some overheating problems so the cooling system was cleaned down all pumps checked and cooling system now fine. Tried a test run but could not get power out of the engine. Suspected head gasket problem but carried out compression test etc and all was fine. Have checked fuel flows, carby, & ditributor and all fine. Engine starts first time always not missing and running fine. Can idle around in gear but when I try to accelerate the engine really labours and starts to heat up. There is no growth on leg or hull and prop OK. Any ideas or has anyone experienced similar problems?"
