I hope this issue hasn't already been covered, i couldn't find any relevant info when i searched through posts and archives (been searching on and off for a few months before becoming a member)
A little background:
My dad gave me his old boat and motor, saying if i could fix it, i could have it. The boat is a pre-1960 14' Wizard fiberglass, and it's got a 1957 Evinrude 35hp Big Twin (model # 25028) with the original Cruise-a-Day 6 gallon pressure tank on it. I've rebuilt the transom of the boat and am working on the motor, and have run into some issues.
I have replaced (with NEW parts):
-Coils
-Points
-Spark Plugs
-Condensors
I've set the timing with a jig and voltmeter, then double (or quadruple, i don't know at this point) checked with feeler gauges, and I've gotten it to fire up once or twice, but it stalled out. Now when i go to pull the rope, the throttle snaps closed, regardless of where it was set or if someone is physically holding the throttle gears. The motor doesn't have a stop button or killswitch anywhere that I've seen, so I'm assuming you're supposed to close the throttle to kill the motor, leading me to believe that the throttle isn't supposed to snap shut, and it doing so is preventing the motor from starting.
Can anyone tell me if my thought process is logical/correct? And if it is, what is causing the throttle to close and/or how do i fix it?
-Coils
-Points
-Spark Plugs
-Condensors
