"Kevin;
There are about a qua
"Kevin;
There are about a quarter zillion 5.7's out there, and there are all kinds of aftermarket performance parts available through the custom engine and speed shop houses.
You can swap heads, intakes, carbs, cams, rocker arms, multiple carbs, stack exhausts, and so on and so on.
You can also buy a "built" marine 350 that will make 400+ hp if you like.
Its all a function of how wild you want to get and how deep your pockets are, and what kind of gas you want to use.
If you start bolting performance goodies on your stock block (consider how many hours are on it), you will of course erode its reliability accordingly. With a blower you can get a 50% power increase, so 400+ hp is achievable. But there is the drive issue, and you could easily blow up the bottom end.
Consider that a boat's top speed will increase as the square root of the power increase. That means that if you power up to 375 hp (50% increase), your speed increase would be about 22.5 %. You would see about 78 mph. That's quite fast for a 19 ft boat; you would be the King of the lake. Meanwhile your fuel consumption would be 50% higher.
Most standard deep V hulls start to get squirrely above about 70 mph, so stability may become an issue. I am not familiar with the traits of the Vindicator.
Rod"
