" sorry i forgot to say i am u
" sorry i forgot to say i am using the 2 line system , iwent through the tank and as far as i can tell it is not leaking. when i took the cover off the motor there was a wire , that was taped with an eyelet just laying there and there was nothing to the centre nut on what i think is the pump. there are 2 ground wires attached to the pump body from the throttle lever i hooked up the eyelet to the centre nut thinking it would be the power wire , but it still doesn't run. i haven't checked the wire for power. does the motor have to be running for there to be power at that wire or will it have power when the battery is connected? how would i check the air pump? the only other place i can think of that i might have an air leak would be at the connector from the tank to the motor.thank you for your help Shane "
