Hello there
Engine shutted off on me while sailing... the upper cylinder pressure so low, the bottom is fine, i pulled the head out
I found a cracked gasket on the top cylinder, removed it, cleaned the head...
here's pic of the head after cleaning and some sanding.. probably needs more work
The Piston seems not fine, i can fit my nail inside the area
what should i do guys? what you think? should i pull the motor all out? i have rebuild 2 stroke bikes before, but this is my first time rebuilding an outboard...
any advice will be appreciated
