hello, i have owned this motor for two years, i have replaced the water pump x2, the thermostat x2, poppit valve, head gasket, exhaust cover gasket, all seals that apply. i have not replaced the powerhead base exhaust gasket, cleaned out all ports and passages, pick up tube from pump, rebuilt carbs, reset ignition timing, now the temp alarm might go off after five mins or three hours, i have always had good telltale streem (luke warm) when alarm sounds i feel and inferred the head for overheating, warm but not hot , i also notice i dont get any spray out of the exhaust ports when the thermostat opens, just steam. i suspect a bad sensor.ok, in the factory parts it shows an inner exhaust plate and an outer cover plate, this motor only has an outer plate?? can anyone advise where to go from here..thank you..wibor
