"It has a dead number 1 hole.
"It has a dead number 1 hole. Both holes have 123lbs compression, both have fire at the plugs. The motor has trouble starting, it has gas and oil thats not buring in the top hole that is being sprayed out the exaust hub on the prop. The carbs have been gone thru, even swaped number one carb with a nother one from a running motor still nothing. Will run across the water at top speeds just fine. Can hold my hand over the top carburator when the motor is idleing and it sucks my hand in but will not shut off the motor, I tried this on bottom carburator and motor shuts off rightaway. Please any help?"
