55 evinrude help
Rambo58
I recently bought a 1955 big twin 25. Model 25018. The fuel line weren't on it. It is not the model with the fuel pump. I would like to know if anyone can tell or show me the correct way to run the fuel lines. I will be using a pressure tank. Thanks
It's not that complex. Do you have the fuel connector? A hose runs from the air side of it to the fitting at the bottom of the intake manifold. Another hose runs from the fuel side to the carburetor. In case you are wondering, the remaining fitting on the intake manifold is for a hose going to the vacuum cut-out switch.
