'55 Evinrude 15 hp fastwin throttle gear/rod replace
honyacker
Just got a '55 Evinrude Fastwin 15 but the throttle gears are shot(all teeth come to points on both gears) and trying to get replacements. Does anyone know if '56 Evinrude Fastwin 15 or a '57 Evinrude 18 would work?
Thanks,
Joe
There were two types of gears. The older ones (yours) were stamped gears with pointy teeth. The change came 1956-ish to cast gears with rounded teeth. You can use the newer style from the motors you mentioned if you replace both gear/shaft assemblies.
EDIT: Yours may not be shot. They may just need some spacers. But the newer round teeth work much better---the reason OMC made the change.
