50hp johnson
movinon
1989 50 johnson, I can get 3/4 to full throttle but no more. My motor surges trying to get full trottle. Took off vro and replaced with pump cleaned up carbs and still nothing. Does anyone have any ideas?
I cannot get a hold of your motor.----You need to provide information.-----Post the results of a compression test first.
This is what the motor sounds like.
Well---87 PSI is low.----So you have a bad gauge or issues with your motor.---What boat ?---What pitch on the prop ?
Could be a faulty gauge. Motor idles good and takes off strong just top speed speed seems to be the issue.
Prop is 13x11 on a 14ft aluminum starcraft.
New tank and hose.
Might be hitting the rev limiter.----An 11" pitch prop would be used on a 20' pontoon boat.----Props / power / boat size / motor condition is a strange concept.
Now I seem to have another issue. Motor will no shut off through the key or saftey switch. I've Check the wiring from the controls to the connector in the wiring box and it's all good. No breaks in the wiring. Could it be the power pack?
