I have a very weed lake with good bass fishing and unfortunately I found a lot of fishing line wrapped around the back of the propeller and further up the shaft. I had a little milky substance in the lower unit as I drained it. It was recommended I get new "grommets" for around the draining screws, which I have. I was reading in the service manual that there is a "seal puller" that can be used to pull the "seal" (342887) from the propeller shaft. Does anyone know how much it costs or what the part number might be for this tool? I am trying NOT to wreck things with a screw driver. It appears this seal is mostly rubber with some spring inside it. Any pointers would be appreciated.
Thanks again in advance.
