"kenneth,if u will start your
"kenneth,if u will start your own post,it wont be buried under another's title...
disc shift cable at eng,at see if u can manually shift it to rev...
ck your fuel hose at tank,there is prob an anti-syphon valve there...repl w/a reg brass nipple,or knock the spring an ball outa your's....they stick.....if nothing there,ck pick-up tube in tank...u obviously have a restriction.u can get just a bendix,but that may not be your problem,clean the spiraling w/wd40 make sure it manually can be moved up freely,....ck batt and connections...load test batt..
A new eng,should come w/a new control box,not sure tho,many chgs being made.."
