50HP Clasic rev problem
R
randy achor
Guest
My 1989 Merc. 50 classic revs
My 1989 Merc. 50 classic revs fine out of water even in gear.. I get about 6000 out of it but when in gear in water only gets up to about 4000. Carbs have just been rebuilt and still same problem. Does not miss or sputter just wont go any higher. Any input would be helpfull.
"Sounds like the prop pitch is
"Sounds like the prop pitch is wrong, The engine will reach WOT out of the water as there is no load on the prop,"
I thought maybe the same thing
I thought maybe the same thing but the previous owner said that the boat used to run fine and wind out. He said it would do 40 and it now only does 20.....Any other ideas??? Thanks.
"check compression, check spar
"check compression, check spark, if good then clean the carbs, sounds like you have a plugged jet. Dont run it as is, if it is a jet then little or no fuel/oil is getting to that cyl, bad things happening"
easy way to tell how your moto
easy way to tell how your motor running
spray carb clean in each carb one at a time
RPM goes up Ur lean
RPM stay the same your rich
RPM drops Ur OK
Hi!
If the above suggestion
Hi!
If the above suggestion does not work then you will have to address TIMING issues on your engine.
Alex
