Bogging is usually caused by a lack of fuel.----Try opening the low speed mixture needles 1/4 turn at a time and test run.-----Post compression numbers too.----Do you have spark on all 4 leads ?-----Has exhaust tuner been checked for blockage ?----Did this problem show up suddenly ?------Looking forward to your answer on each question.
ok so I just changed the spark plugs ,no help, the fuel mixture screws did not react much.
I'm not familiar with the exhaust tuner I never herd of it but it seems to be fine.
the problem did show up suddenly but heres how it went;
launch boat idol nice, head out no wake zone ,ok
open water bring up throtel to full ,seems fine set trim tab,nose came down on plane.
20 seconds later engine bogs out like its out of fuel.
pump ball hard, no kinks in hose. back to idol ok ,will not throttle up in fowaed
neutral reves high, reverse revs high. no forward.
