50hp 87 evinrude misfire
j4jaker
Ok I'm stumped
I have this same motor and it starts no problem when cold. However the top cylinder continues to misfire after swapping coils. Did a leak down and compression test and all was good. Have fiddled with the adjusting screw on the carbs and no change.
Any help would be appreciated
???-----If you put straight gas in the tank it should have a working VRO pump.----Remember that no one here can see or hear your motor.
Ok sorry first boat still learning all the terminology. So yes I have a VRO pump and it is working properly as I am getting fuel to both carbs no problem. But the top cylinder have verified spark and compression and still getting a miss
Read carefully----Does spark jump a gap of at least 3/8" on a test device, yes or no ?----And what are the actual compression values ?
I have not tested spark jump with a tool however I can hold about an inch from the block and it reaches the block. The compression values on top cylinder is 130 and the bottom cylinder is 140
