"Granted I'm no mechanic,
"Granted I'm no mechanic, but I usually can figure things out. A neighbor has a nice little 17ft flats type boat with a 50hp 2stroke yamaha on it that hasn't been run in about a year and a half. She said if we could get it running we could use it all we like here in Charleston! Anyway, I took the cover off, checked everything out, put a charger on the battery and after a few tries, got it to fire up. Granted, I never got it to maintain a good idle. I did clear a clog in the cooling discharge line. I noticed that there are two threaded holes at the front top of each of the three carbs. The bottom carb is POURING gasoline out of the aft of these two holes. Is this a sign that I have old gelled fuel in the carbs and that the lower carb is the only one functioning? Any help or thoughts would be appreciated. The engine fires right up and I adjusted the idle which allows it to run for a while, but I'm not comfortable with that steady flow of fuel out of the lower carb.
thanks in advance of your suggestions!!"
