50ELPTO not getting on step
worktoeat
I am having trouble with the motor not getting out of the hole. It is a 2008 50 hp oil injection 2-stroke. Any suggestions? I have changed fuel filter and the complete fuel line.
OK then---If it sat all this time then the carburetors might be plugged / gummed up.---Time to take a look.
I've cleaned carbs and changed plugs and fuel lines and filters. Fresh gas in tank. Engine starts and runs fine. When I get on it to get out of the hole it will shoot out then fall on its face. I can run all day at what seems to be half speed and never will engine die or miss
May not be running on all cylinders. Using insulated pliers disconnect one plug wire at a time at idle to see if engine RPM changes.
