Hello Marine Engine Guru's
i have a pair of 502 Crusaders that won't come up over 3000 rpm. / significant loss of power.
I have done about everything.
new plugs, wires, caps, rotors, been through the carbs and put on a Dyno to verify fuel flow prior to reinstalling carbs.
pulled distributors cleaned and reassembled .
Time ing right at 8 deg.
compression check both engines and all holes are 150 psi.
propellers are excellent and have been scanned for accuracy.
the issue is the sudden loss of RPM at WOT. We took a boat trip about 50 miles one way. Both engines ran great. On the way home it was like we were running with 60% less power.
the above checks and total tune up was done and still lack of rpm. No change.
the boat is a 1990 Carver 380 with 500 hrs on both engines. Uses no oil and does not leak any as well.
Any ideas?
Thanks,
Gary
Any ideas?
Thanks,
Gary
