I have purchased a 1999 Nissan 50hp and have some questions, while running it in a 15 gallon tote bin it was not giving much of a tell tale and then a smoky tell tale. The 15 gallons of water were covering the cavitation plate by one inch about 2 inches above the inlet ports. I purchased a garbage can that will go deeper for the engine and will try that. I'm in Michigan and during the winter it's hard to use the earmuffs for cooling water. My questions are the following, was the water to low at one inch above the cavitation plate? When servicing the water pump is it a roll pin to seperate the shift linkage, can it be tapped out/in with no damage to its seal while pulling the lower unit? How much should I expect to pay for new impellar and related parts? Last question, where the block mates in the crankshaft area there is a gooy red sealer slightly protruding in spots, I've seen this used on transmissions cases before, does this mean the block has been worked on or is that a stock sealer? I just bought the outboard and hope it has not been worked on before. Lastly will these engines perform as good as the big three? Johnson/Mercury/Yamaha??
