50 HP EVINRUDE REBUILD
G
Gary G
Guest
I am rebuilding my 50 hp 2cyl
I am rebuilding my 50 hp 2cyl Evinrude. What type of gasket sealer do I use between the case halves of the power head???
Gary
" Also, what do you recommend
" Also, what do you recommend for pre-lubing the bearings...Is a mixture of stp and oil ok ??
Gary "
You can use the factory recom
You can use the factory recommended "gel seal" .It is most important to make sure that there are no imperfections on the surfaces.Use the sealer sparingly. I have measured the film of sealer on failed powerheads at 0.008" which means the assembler had no idea on what they were doing.
