riverdawg1
I have a 1995 Evinrude 50(e50tleod). It won't idle unless I give it a little throttle and it tops out at 9 mph, I usually get about 30 mph, at wot. I've changed fuel filter. I checked replaced spark plugs and tested the spark is blue and jumps 1/2" on tester. I've never run ethanol gas in the 3 years I've had it. 2 weeks ago went out on Thurs and it ran fine except rough idle. Then that sat it started bogging down and would only go about 12 mph but after about a mile or so it slowly got up to 20 mph and barley in plane I sprayed cards with sea foam and replaced plugs and checked spark this past weekend took it out again and won't idle without throttle and top speed was 9mph and never would get on plane can someone help in where to start? I'm thinking maybey rebuild kit for carbs? Thankse
