Guys,
To start with my problem (from 6 seconds onwards): https://youtu.be/YbdG-p2ooUw
Background...
I've been working on my 2nd hand bought 1987 Evinrude 50HP (E50BELCUD).
On the first test run idle was fine but the engine died immediatly on throttle.
I replaced the VRO pump with a generic fuel pump: OEM replacement Part # 433386
Vendor states this would be the correct replacement part. (https://www.allesmarine.nl/omc-benzine-pomp-of-voor-ombouwen-vro-naar-normaa.html)
Looking at the part number it seems like this is for a 20-30hp engine. But I'm still confident about good advice from the vendor.
I've also replaced the carb float chamber incl high speed jets which were very bad. (new jets are full open)
With these replacements I was positive about a good running engine but on test it only runs 10Km/h on full throttle and is halting.
Here's how it sounds: https://youtu.be/YbdG-p2ooUw
Fuel line, jets etc are all clean.
Looks like a fuel issue but I have no idea what it can be.
Any thoughts?
Background...
Any thoughts?
