50 HP 1982 Mercury
dhowell
"My motor, isn't getting g
"My motor, isn't getting gas, when I pump the primer it is real tough, the boat won't idle and dies if you go from Fwd to Reverse. It isn't sucking gas into the engine. It won't get up and run either only putts along at 1000 RPM's. Any suggestions for troubleshooting the Gas Pump or hose etc"
You may have plugged carbureto
You may have plugged carburetors and you should sort this problem out before running it again. Remember no fuel going into the motor also means ----NO OIL.
