"Hello.I have a 15 hp Yamaha t
"Hello.I have a 15 hp Yamaha that has no spark.It's a 1985 sk motor.The kill switch is working as it should and is not the problem.There are 3 wires coming out from under the flywheel,brown(engine start),white/red(coil pulser),and black(ground).When I push an electrical test probe into the connectors the only one that lights up is the brown lead when I pull the starter cord.Should I see some juice coming from the white/red wire(pulser) when I pull the cord? Could the coil pulser be bad?If so can anyone tell me how to check the coil pulser,cdi box and coil?Any help would be appreciated.Thank you."
