5 hp water pump replacement instrutions
david_sims
"I have a 5 hp 2000 2 stroke M
"I have a 5 hp 2000 2 stroke Mercury regular shaft. If you have instructions on how to replace the water pump I would appreciate having them.
Thanks,
David"
"I attempted to remove the low
"I attempted to remove the lower unit to replace the water pump. I removed a 13 mm and a 10 mm bolt. The unit would come down an inch or so and stop. Obviously something is holding it in place. If you have step by step instructions for replacing the water pump I would appreciate having them.
Thanks,
David"
The gear shift rod needs to un
The gear shift rod needs to unhook. There should be an access panel with 2 bolts right behind the carry handle. Underneath the plastic lower cowl There is a small cube clamped to the shift rod farther down that comes off that moves the reverse look hook. Take that off.
